Extruder calibration
alexander.m7
(@alexander-m7)
So this may be a dumb question but when doing move axis on the LCD screen what are the units of number that displays for the Extruder axis? Is it steps, or is it mm? I am trying to calibrate my extruder with a new hobbed gear so I can change the value in the firmware
Respondido : 23/08/2018 4:46 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Extruder calibration
It's millimetres
But you are better of connecting via Pronterface/OctoPrint and issuing a command like:
G1 E100 F120
Which will feed 100 mm of filament at 2mm/s (120mm/min)
But you would also need to issue the following first:
M83 ; relative "E" values
G90 E0 ; Initialise "E" value to zero.
Peter
Respondido : 23/08/2018 5:01 pm
Chris
(@chris-50)
It's millimetres
G1 E100 F120
Peter
Does one need to zero the extruder when using relative positioning?
Respondido : 23/08/2018 9:56 pm
PJR
 PJR
(@pjr)
No, but it's a good idea. {this next it is how things were last time I looked and may have been changed since} Even though you are using relative positioning, it is the absolute position stored in a "Float" (not very precise) that determines E movement. So after a long print, 100 mm may not be quite the same as after initialising the position.
I am now in the habit of issuing the "G90 E0" at every layer change.
Peter
Respondido : 23/08/2018 10:06 pm
Chris
(@chris-50)
Peter
Interesting, I'll give that a shot it can't hurt.
Respondido : 24/08/2018 4:05 am
