Error: Loose Pulley Motor
scott.b6
(@scott-b6)
Hi there guys,
Firstly I have an i3 MK2.  I don't know if its a MK2S or not.
I am running the wizard calibration and it keeps stopping and saying "Loose Pulley Motor.   The X Axis belt seems taunt enough, but I am not sure.
Any help would be appreciated.  Thanks everyone!
Napsal : 02/06/2020 8:08 pm
kenatno10
(@kenatno10)
RE: Error: Loose Pulley Motor
Hi , i had simliar on mk3s
Slacken off belt tension and slacken off belt pulley screws. Do the 2nd screw first , then the flattened surface one . Retighten the reverse way. Check belt and pulley alinement across the uprights and for the belt running true.
Retension belt , needs to twang abit like a guitar string , if the belts touch they are likely to still be to loose , so shorten slightly.
Napsal : 02/06/2020 8:39 pm
scott.b6
(@scott-b6)
@kenatno10
I will try that but I am not sure which is the "second" screw.
Napsal : 02/06/2020 9:23 pm
the X motor assembly is the same for either the Mk2 or Mk2S
https://help.prusa3d.com/en/guide/3-x-axis-assembly_89912
Napsal : 02/06/2020 11:44 pm
scott.b6
(@scott-b6)
@joantabb
Ahhh thank you!  Still have a dumb question....which is the "first" and which is the "second"?
Napsal : 03/06/2020 2:01 am
