Cooling Fan Anomoly
martin.e5
(@martin-e5)
Cooling Fan Anomoly
I have a MK2 i3 running 3.1.0 firmware and the cooling fan does not come on during prints. It does however work when turned on manually using the settings->tune->fan speed while not printing. I have tried prints with gcode generated by Simplify3D and Slic3r PE with same results. During the print the fan speed is set correctly to 100% (255) yet the fan does not spin. Any help would be appreciated.
Napsal : 07/09/2018 7:46 pm
