Chattering sound
SESTAVSI.cz
(@sestavsi-cz)
Chattering sound
My extruder makes chattering sound and feeding wheel just slippin. I was printing with ABS before than I switched to PLA and this happened but same thing after swtiched back to ABS
Opublikowany : 20/12/2018 10:30 pm
alexander.s27
(@alexander-s27)
Re: Chattering sound
Your video shows 210° which is way to cold for ABS. If you did no cold pull when switching from ABS to PLA there are remainders of ABS which will not even melt.
Opublikowany : 21/12/2018 7:56 am
SESTAVSI.cz
(@sestavsi-cz)
ofc I am using 255°C for ABS, this is PLA
Opublikowany : 22/12/2018 6:52 pm
alexander.s27
(@alexander-s27)
Oh yes!
But what of the ABS is still there in the hotend and nozzle will not melt at that temperature and is causing your clogged nozzle!
Anyhow I seem to remember that a mixture of PLA and ABS could even react unpredictable.
Thats why I recommended a coldpull which at least provides a nozzle without residues of previous used material.
3D-print basic knowledge I dare say....
Opublikowany : 22/12/2018 7:18 pm
SESTAVSI.cz
(@sestavsi-cz)
basic knowledge 😀 I am printing about one year switching ABS and PLA with no problem. I always put every last piece of ABS before changing the temperature. Anyway as I said before the extruder doesn't want to take even ABS even with higher temperature (270°C)
Opublikowany : 23/12/2018 9:54 am
