Change the size of the heated bed
nicolas.d3
(@nicolas-d3)
Hi. every one.
I currently own a Prusa I3 MK2. I had a problem with my heated bed. The nozzle is returned to the bed and the thermal resistances have been damaged. So I had to change the bed. The only one I found is slightly smaller than the original. The problem is that, at the beginning of printing, during the calibration, the nozzle tries to calibrate itself outside the bed since the new one is smaller. It is therefore impossible to calibrate and make impressions. It should either change the bed size in the software of the printer (I do not know if this is possible) or remove the automatic calibration before each print.
Here is the new bed I bought :
https://shop.prusa3d.com/en/electronics/48-heated-bed-mk2b.html
New size are 200x200 mm and before I change I had 25 x 21 cm. (I could fix it without worries, the points of attachment had the good dimensions.)
Any idea to help me ?
Thanks.
Publié : 25/06/2018 9:52 am
BillC
(@billc)
Re: Change the size of the heated bed
Contact Prusa using the Chat option in the bottom right corner of the screen when you log in to the shop using the email ID you used when you purchased your machine. Tell them you bought the wrong bed and ask them what you can do.
No-one else can help you.
Sorry.
Bill
Tagaytay City, Philippines
Publié : 25/06/2018 12:50 pm
