Bed Thermal Runaway; Sequential Printing
jeffrey.a3
(@jeffrey-a3)
I have tried this print 3 times. Each time the first 20mm of the first print complete fine. As the first layers of the second print start, the bed temperature begins to drop and the system stops at almost the same place on the third layer. The model was processed in Simplify 3D using two processes. After the print stops, I can set the bed temperature back to 100 without issue. What is going on?
Opublikowany : 07/04/2018 4:03 pm
