Bed leveling issue
cz7asm
(@cz7asm)
Bed leveling issue
I noticed when printing larger parts that first layer isn't evenly "squished" and due to this some parts are more likely to warp. I've tried the Bed Level Correction option but I didn't notice any improvement (perhaps I got the setup wrong).
In the first picture I attached you can see that the upper middle circle would need more squshing and the upper right one is squished too much. I thought the mesh bed leveling feature should deal with this so I suppose the bed has some problems that cannot be compensated for.
The other two pictures only confirms the problem in the upper middle region.
I guees this is a mechanical issue - is there any way how to deal with this? I was thinking about the MK2.5 upgrade - are those parts any better in terms of leveling?
Thank's for help.
Publié : 14/11/2018 9:18 am
Re: Bed leveling issue
Not really an answer, but I've seen this too. Where one side of the bed is fine, the other side seems too squished. I am almost thinking this issue started with the latest 3.4.1 firmware, or 2.2.1 Slic3r, but haven't down-rev'd to check. It could also be my imagination.
But I just remembered that I have had issues with 'debris' stuck under the PEI sheet raising certain areas. A 9-point cal can't catch everything.
Publié : 15/11/2018 1:33 am
