Bed Heater fail
Hello, have following problem on my MK2S, bed stopped to heat, checked everything, connectors, heater resistance (1 ohm), etc. Found that without the heater connected the output is 12 VDC and the red LED on the board turns on, but when I connect the heater falls to 0 VDC and the red LED on the board turns off.
Thanks for any help
Napsal : 04/10/2022 10:55 pm
RE: Bed Heater fail
Sounds like there is a dead short in the wire going to the bed from the 12v source.
Napsal : 05/10/2022 7:57 pm
Topic starter
answered:
RE: Bed Heater fail
HI, Thanks for writing, no, I checked the cable, tried with an old MK42 heatbed, same behaviour
Napsal : 05/10/2022 8:30 pm
