Adhesion - Ender 3 PRO vs Prusa PEI/Textured sheet
mrmossevig
(@mrmossevig)
I've had my Prusa for something like 3 months now, using mainly the PEI-sheet. I've tried the textured steel sheet, but was never able to get good any successful prints on it. In the end my usual setup is just the PEI-sheet with glue. Printing mainly PLA but also some PETG and tried some ABS (Almost impoosible because of the warping).
I have tried everything including soap and water and cleaning with acetone. Acetone helps the PEI-sheet for maybe one print, then I have to go back to glue.
Then I got the Ender 3 Pro with the magnetic, flexible sheet and holy cow! The adhesion on these are so good, and it's so easy to get a good first layer and clean, tall prints.
So, to those of you with the experience with both, is that your experience as well? Or did I get a bad sheet with my Prusa printer?
Napsal : 15/04/2020 11:11 am
