A piece from PEI is gone. Do I need to replace the sheet?
theologos.m
(@theologos-m)
A very stubborn part (printed in HDGlass, which is based on PETG) took away with it a small piece from heatbeed's PEI sheet. The piece missing is small (6 x 8mm).
It doesn't bother me how it looks on the printed parts.
Should I replace the PEI sheet? If yes, how quick should I act? ...or can I continue printing?
Respondido : 03/10/2018 5:17 pm
Knickohr
(@knickohr)
Miembro Moderator
Re: A piece from PEI is gone. Do I need to replace the sheet?
Continue printing but avoid printing on this defective place..
Thomas
Respondido : 04/10/2018 10:27 am
PJR
 PJR
(@pjr)
Antient Member Moderator
As a temporary measure, you could fill the hole with glue stick, but you certainly don't want to be printing directly onto the heater elements.
Peter
Respondido : 04/10/2018 11:35 am
