Upgrading MK2S with leftover parts from MK3S to MK4
Bytor
(@bytor)
Hello everyone,
I have a 2 MK2S, one has a MMU1 attached to it sitting in my office at work. At home I upgraded my MK3S to a MK4 and was wondering about upgrading one of the MK2S to a MK3S.
I have the MK3S heatbed because I got a new one for the MK4 upgrade. I think I just need to get a 24V power supply, which work would buy so that's not an issue.
Is the MK2 Y-carriage the same as the MK3 Y-carriage? Am I missing anything?
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Postato : 22/02/2024 4:14 pm
RE: Upgrading MK2S with leftover parts from MK3S to MK4
the mk2 frame is smaller than the mk3S frame
there were alternative Z  axis top and bottom parts that can help they were made to restore  z height when using volcano...
you would also need a 24 volt power supply to get the best out of the parts
Postato : 22/02/2024 7:22 pm
Bytor
(@bytor)
Joan,
Thanks for the information about the frame and z-axis. I was able to find the Z files. Now, jus to find the time to make this Frankenstein 😀
- 3rd PRUSA i3 MK2S
Postato : 23/02/2024 12:50 pm
Welcome to the Frankenprusa brigade...
I forgot. The Y axis platform is different. The MK3 heated has different mountings  first time I created printed strips to support the MK3 heated.
Later I found a spare MK3 y platform... But I needed to adjust the frame corners a tiny bit. To match the MK3 bearing spacing...
Regards joan
Postato : 23/02/2024 2:29 pm
