Upgrade price from the MK2S to MK3S
Warnings
(@warnings)
Hello,
Prusa seem very busy to produce all new orders for probably new customers so why this kit is so expensive for upgrade a MK2S to MK3S ?
Customers have already payed full price and margin for the MK2S why no just decrease upgrade price and free a little the production line due to not part to print for Prusa just put some materials in a box and not seem to cost really the asked price but not know enough. So probably people buy another full printer instead of upgrade and production line more busy because more cheaper to buy a new MK3S than an upgrade kit.
Why the MK2S haven't power panic integrated ?
It's not just a software/firmware function need really some hardware for that ?
Thank you 🙂
Opublikowany : 08/09/2020 9:04 pm
RE: Upgrade price from the MK2S to MK3S
The upgrade from MK2S to MK2.5S is cheaper and includes the filament sensor. This option is specifically described as a cheaper upgrade than the more expensive upgrade from the MK2S to MK3S.
Opublikowany : 08/09/2020 9:54 pm
1 ludzie polubili
Warnings
(@warnings)
It's true but not "PowerPanic" for the MK2.5S
Opublikowany : 08/09/2020 10:11 pm
Clemens M.
(@clemens-m)
@warnings007
Because there are many changes between MK2x to MK3
MK2x ==> MK3x (x ... different evolutionary steps of the printer)
12V ==> 24V
completely new printerframe
new microcontroller board with new features (power panic, ...)
6 fixation points between y-axis carrier and heatbed to 9 points
So If you really want to have a MK3S it is (in my opinion) cheaper to by a new MK3S and sell yout old MK2S. If you want to get a printer with a lot of the features of the MK3S take the upgrade to MK2.5S. It has no powerpanic - I live in Austria and I am printing since 2017 - I never had a problem with that, so the MK2.5S is ok for me.
Best regards, Clemens
Opublikowany : 09/09/2020 4:23 pm
Nikolai
(@nikolai)
Posted by: @warnings007
Yes, it requires some hardware. Beside the additional controller board, the Einsy board was designed for that. Here you can read more details:
https://reprap.org/forum/read.php?159,831103,831103
no it will also work at 12V
all it does it acting like a switch, when mains is present it makes creates a connnection and passes either 24V or 12Vwhat makes the einsy "special" is that the bed and extruder heater will be disconnected as soon the power panic signals that mains is gone.... its done at the hardware level
on top of that one of the pins on the mcu is also connected to this "line" so that it can act on what happens
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 09/09/2020 4:53 pm
Warnings
(@warnings)
@clemens-m
Yes what I think too but sad to buy a whole new printer instead of upgrade some parts. It's the purpose of Prusa printer to upgrade without
should pay a new printer each time 🙂
@nikolai-r
Thank you for explanation and link
MK3S contain all + printed parts for only 250$ more ?
Need a lot of print time, lot of job at the Prusa factory for assemble a new printer so just can't follow orders but an upgrade it's just put some parts in a package and ship is almost the same price ?
When the new model come OK I can understand but MK3S released beginning of 2019 now we are at the end 2020 probably a new MK4 model come out soon and still a so high price for upgrade an old printer. I like Prusa like his history produce really good printer but upgrade price isn't really fair. I think you can buy all parts for cheaper one by one... Huge order of parts have probably big discount too so 200-300$ should probably be a better upgrade price with some margin remaining to Prusa 🙂 (600$ mk2s + 200$ = 800$ for mk3s still more expensive but an affordable upgrade path... 800$ mk3s upgraded and again 200$ (~2 years after release date) = 1000$ for mk4 still ok maintenance cost for have upgraded parts latest technology and brand new parts.)
I'm alone to think that ?
Prusa win a better margin when you buy the brand new latest model and still win some money on each upgrade but people stay with their Prusa printers for life and not try to switch to another model/brand beacause at 500$ each 2 years you can buy a brand new lower model printer each 2 years with saving money for repair and change some parts. Upgrade is a business too less time consuming but at this price it's almost a no go.
Opublikowany : 09/09/2020 10:05 pm
Nikolai
(@nikolai)
@warnings007
Upgrading MK2 to MK3(s) doesn't really make sense. Most of the parts are different due to to 12V->24V switch. Even Mr Prusa said that. But he still decided to offer this upgrade path for the people who still want to do this anyway.
You need to see it from the different perspective. If you used your MK2 for couple years and the parts need to be replaced anyway due to the heavy usage, you might want to spend $500 for a (let's call it) refurbished MK3 instead of buying a new printer for $750. I think it's a fair price and move from PR. To have this option at all is a huge benefit which you will not find in the wild a lot.
If your MK2 printer is still in good condition, best option is to go the MK2.5(s) route. Because you're pretty close to MK3 printer and can use the same flex sheet. For those people the upgrade costs $150. It's discounted because I don't remember the reason anymore :).
Often linked posts:
Real Multi Material
Opublikowany : 09/09/2020 11:21 pm
