Upgrade MK2/S to MK2.5S kit discontinued - alternatives?
Clint
(@clint)
I was looking to upgrade my MK2S to an MK2.5S and discovered that the upgrade kit was discontinued at the end of last year. I've managed to find what I believe are all the parts required separately on the store except a "v-cable adapter" for the hotend fan and the variety of nuts and bolts (and other things) that can be seen in this image from the upgrade manual: https://d17kynu4zpq5hy.cloudfront.net/igi/prusa3d/WCjrLMSKHqMJLmPJ.huge
Has anyone else gone this route and able to point me to the "v-cable adapter" and is there a listing of the contents of the two nuts/bolts/misc bags that are required of the upgrade?
Thanks!
Upgrade item listing for reference (total comes to $212, not much more than the original listing price of the kit):
$99.71 Magnetic heatbed MK52 12V (assembly)
$49.99 Bondtech drivegear (set)
$15.36 IR filament sensor
$3.81 IR Filament sensor cable MK2.5S
$3.81 FAN SHROUD BL MK3S MMU2S MK2.5S
$13.49 Hotend fan Noctua
** says needs "v-cable adapter" cannot find this on store **
$25.99 SuperPINDA
Publié : 23/01/2021 11:57 pm
Membre
RE: Upgrade MK2/S to MK2.5S kit discontinued - alternatives?
Every so often, they are available on eBay.
Publié : 24/01/2021 3:49 am
1 personnes ont aimé
Jonathan
(@jonathan)
The v-cables are offered on the e-shop under a different name:
Noctua v-cable - https://shop.prusa3d.com/en/mk25mk25s/678-mk25-noctua-reduction.html
Pinda v-cable - https://shop.prusa3d.com/en/mk25mk25s/677-mk25-pinda-reduction.html
Furthermore, I too am looking into compiling the upgrade list, since the kit is discontinued, but the only thing I am currently missing is the fasteners (nuts and bolts) you mentioned. Might just have to source those locally.
Kind regards,
Jonathan
Publié : 20/02/2021 10:00 pm
fgebhart
(@fgebhart)
With respect to the U-bolts you should probably be good using these: https://www.prusa3d.com/product/u-bolts/
Seems like the links to the v-cables you shared are unfortunately no longer working. Is anyone aware of an alternative source for these? Or do they maybe again go by a different name?
Publié : 15/12/2021 8:19 pm
