[Sticky] The most important links - Original Prusa i3 MK2/S
Jakub Dolezal
(@jakub-dolezal)
Member Admin
here is the list of the most important links for your printer:
User Guide
The video is in English
Brand new user guide for the MK2/S
https://www.prusa3d.com/new-user-mk2s/
Online Assembly manual:
-- English -- http://manual.prusa3d.com/c/Original_Prusa_i3_MK2S_kit_assembly
-- Italian -- http://manual.prusa3d.com/c/Assemblaggio_Original_Prusa_i3_MK2S_kit
-- Polish -- http://manual.prusa3d.com/c/Jak_zmontować_zestaw_Original_Prusa_i3_MK2S
-- Spanish -- http://manual.prusa3d.com/c/Kit_de_montaje_Original_Prusa_i3_MK2S
-- German -- http://manual.prusa3d.com/c/Original_Prusa_i3_MK2S_kit_Bauanleitung
-- French -- http://manual.prusa3d.com/c/Original_Prusa_i3_MK2S_Montage_kit
3D printing Handbook:
-- English -- https://www.prusa3d.com/3dhandbookMK2
-- Italian -- https://www.prusa3d.com/downloads/manual/prusa3d_manual_mk2_it.pdf
-- Polish -- https://www.prusa3d.com/downloads/manual/prusa3d_manual_mk2_pl.pdf
-- Spanish -- https://www.prusa3d.com/downloads/manual/prusa3d_manual_mk2_es.pdf
-- German -- https://www.prusa3d.com/downloads/manual/prusa3d_manual_mk2_de.pdf
-- French -- https://www.prusa3d.com/downloads/manual/prusa3d_manual_mk2_fr.pdf
Latest drivers including Slic3r PE and PrusaControl:
https://www.prusa3d.com/drivers
Latest firmware:
https://www.prusa3d.com/drivers/#firmware
How to upgrade firmware: link
Printable printer's parts:
https://www.prusa3d.com/prusa-i3-printable-parts/
Recommended settings are 0.2 Normal and PETG/ABS
Printable 3D models:
Models are part of the driver's package
Prusa knowledgebase:
http://help.prusa3d.com
Original Prusa i3 MK2/S spare parts:
https://shop.prusa3d.com/en/30-mk2-spare-parts
You must be logged in to see the spare parts,
in case of issues, contact our support
MK2 Knowledge base
https://help.prusa3d.com/l/en?tag=MK2
In case you think, something is missing, please let me know below and as always Happy Printing! 😉
This topic was modified před 7 years by Jakub Dolezal
Assembly manuals
/ Knowledge Base
Napsal : 12/01/2018 11:09 am
Re: The most important links - Original Prusa i3 MK2/S
Thanks Jakub
Regards Joan
Napsal : 03/05/2018 9:42 pm
mike.c22
(@mike-c22)
How do I get access to the spare parts shop? Says I do not have access
Napsal : 03/12/2018 3:11 am
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Mike you need to sign in, also the spare parts are available only to those, who bought the printer.
Assembly manuals
/ Knowledge Base
Napsal : 04/12/2018 12:23 pm
heidiaebrown
(@heidiaebrown)
RE: The most important links - Original Prusa i3 MK2/S
Hi there, a friend gave me their old / built Prusa i3 MK2. I fired it up, heated the hot end, loaded PLA, did a calibration and all is well. Then, I downloaded a Gcode (Prusa frog and a random cat I found) and tried printing a few times, that first layer is not sticking. Help!?!? Why would calibration work but not the print. Ideas are great, I'm green at this 3d printing stuff. Should I use glue or hairspray? If so, what kind. Second question is creating Gcode files. I use a PC and looks like the Prusa softare is for Mac(?) I might be able to use husbands Mac for the prusa software if needed. Which software do I use to made Gcode files from STLs? Help is much appreciated to point me in the right direction, this is all a little foreign language for me!
Napsal : 19/10/2020 6:21 pm
PRNTR3D
(@prntr3d)
@heidiaebrown
Got my first one recently too, and also would not stick.   Try putting a layer of blue painters tape on the bed where your print it.  Fixed my issues.  Also try using the brim/raft and supports are important.  Sometimes with our older machines I have found that I need to download the STL and slice for my machines settings with a custom profile.
Napsal : 13/01/2021 5:51 am
PRNTR3D
(@prntr3d)
@heidiaebrown
Also, the Windows versions of Prusa Slicer and Prusa3D are available on the Prusa site.
This post was modified před 5 years by PRNTR3D
Napsal : 13/01/2021 5:52 am
Alain
(@alain-2)
Bonjour à tous,
le lit chauffant de ma Pursa MK2 est hors service,
mais je ne trouve pas de site où en acheter, je sais que la réf est MK42 et que c'est du 12V.
L'un d'entre vous aurait il me dire où en acheter un ou alors quel plateau serait équivalent?
Merci d'avance
Napsal : 16/12/2023 5:48 pm
