Simplify3D (S3D) settings for the Original Prusa i3 printers
Page 9 / 18
Rutilate
(@rutilate)
Re: Simplify3D print settings (August 30, 2016)
If you export out your FFF config and edit the file (in something like Notepad++), at the bottom will be the the material config, which usually won't have a lot in. If you add a parameter for retraction speed, then you have to add the same parameter for all materials. If you don't then it'll use what ever was last specified.
you go from something like
<autoConfigureMaterial name="PLA">
<globalExtruderTemperature>200</globalExtruderTemperature>
<globalBedTemperature>60</globalBedTemperature>
<globalExtrusionMultiplier>0.9</globalExtrusionMultiplier>
<fanSpeed>
<setpoint layer="1" speed="0"/>
<setpoint layer="2" speed="100"/>
</fanSpeed>
</autoConfigureMaterial>
to
<extruder name="Primary Extruder">
<toolheadNumber>0</toolheadNumber>
<diameter>0.4</diameter>
<autoWidth>1</autoWidth>
<width>0.48</width>
<extrusionMultiplier>0.9</extrusionMultiplier>
<useRetract>1</useRetract>
<retractionDistance>1</retractionDistance>
<extraRestartDistance>0</extraRestartDistance>
<retractionZLift>0</retractionZLift>
<retractionSpeed>1800</retractionSpeed>
<useCoasting>1</useCoasting>
<coastingDistance>0.2</coastingDistance>
<useWipe>1</useWipe>
<wipeDistance>2</wipeDistance>
</extruder>
<fanSpeed>
</fanSpeed>
Can you share a copy of your FFF? My question is this extruder now only associated with the material and not the quality?
Posted : 15/10/2016 9:10 pm
Matt3o
(@matt3o)
Comparing slic3r and simplify3d options I noticed something weird.
For PLA 0.05 travel speed on Slic3r is set to 200mm/s on S3D seems to be 4800mm/min which should be 80mm/s
Perimeters speed on Slic3r is 40 mm/s while on S3D is 60% of the default printing speed, or 2400/60*0.6 which is 24mm/s
Solid infill on Slic3r is 40mm/s on S3D 32mm/s
Wondering why so much difference between the two.
Posted : 16/10/2016 9:54 am
Robrps
(@robrps)
Yes those extruder settings would now be material specific. The FFF files are limited, you can't have some extruder settings under quality and some in material, it's all in one, or none in both. That just down to the way the XML file is structured.
I've attached my FFF file, with just two material profiles, I would suggest that you delete all but one, work on that one and then when you are ready to add more material, just click the green plus button to add a new one, then change your settings and update the profile.
I wrote down which settings I considered to be machine specific, which are material specific and which are quality specific. There were some overlaps on some settings (such as speed), but once I had them written down it was easy to put those in to one of the 3 categories - I can always change the setting manually if I think I need to.
Unless otherwise stated the settings below change on a material basis
--Extruder settings
  • Nozzle diameter
  • Nozzle Width
  • Multiplier
  • Retraction
  • Retraction Distance
  • Z-Lift amount
  • Retraction Speed
  • Coasting Distance
  • Wipe Distance
  • Extruder Temperature
    Bed Temperature
    Fan Speed
    Fillament Diameter
    Fillament Price
    Fillament Density
    And these are the quality settings
    Layer Height
    Infill Percentage
    First Layer Height Percentage
    First Layer Width Percentage
    Top Solid Layers
    Bottom Solid Layers
    Perimeter Outlines
    Outline Underspeed
    Solid Infill Underspeed
    Support Underspeed
    This FFF is specific to my printer though, so check before printing anything. I'm using PrintBite instead of PEI so my bed temps are hotter and I've PID tuned both my extruder and bed temps. Your mileage may vary! ...and yes I do need to move my PID settings to be material specific...
    Posted : 16/10/2016 2:23 pm
    midget
    (@midget)
    After some playing around, so far I have been getting much better results with Verbatim Black PLA with the following settings
    Temp
    First layer ; 220
    Rest : 210
    Bed : 55C
    Retraction
    Retraction distance : 3mm
    Restart Distance : -0.2mm
    Wipe Nozzle : 3mm
    Coast at end : Off (0.2mm coasting seemed to cause under extrusion)
    Retraction speed : 30mm/s
    Vertical Lift : 0.2mm
    Other
    Layer start : Closest at X = 0, Y = 0
    Posted : 19/10/2016 7:16 am
    Eric Gormly
    (@eric-gormly)
    I hope I am not hijacking this thread but as I am still new to all this I am chock full of questions. I have used a lot of the info here to make my own fff and it is working spectacularly (thanks all) My tops and sides of calibration cubes look awesome.
    When I print out a small model and I use a 4800mm speed setting, it goes faster. If I lower it to 3600 it goes slower and so on. This I understand. But if I change the settings to .1 layer height over say a .2 layer height, the difference in print time is HUGE and really pronounced if I change to .05. I also understand that, it extrudes less material, therefore it takes longer.
    My question is...
    If I select a model to print at 0.05, will the entire model, infill and all be printed at that layer height? Is that why the time is so much longer and if so, is there a way to print infill and everything not the outermost shell at a higher layer height to speed it up?
    Posted : 23/10/2016 12:06 am
    Omikron
    (@omikron)
    My question is...
    Yeah, unfortunately that's just the way FDM printing works. The layer height controls the height for the *entire layer* including infill. There is simply no other way to do it. I suppose in theory one could try to write a slicer that does thinner perimeters and and thicker infill layers by alternating layers and some other black magic, but I'm not sure the strength/quality would turn out the way one would want. An interesting idea nonetheless.
    Posted : 23/10/2016 3:22 am
    PJR
     PJR
    (@pjr)
    Antient Member Moderator
    Unless you use KISS (PRO version only) to slice your model... It has a very nice option, "Stacked Layers" where sparse infill and support are extruded every N layers.
    Peter
    Posted : 23/10/2016 11:20 am
    Omikron
    (@omikron)
    Peter
    Well, it looks like someone already wrote the feature into a slicer! I also found "sparse infill" as an option in S3D which appears to do the same thing, although in S3D it's limited to 1.2x the layer height in order to prevent quality and strength problems, which is why in my opinion it's not a super great idea in many cases.
    That said, I suppose that if a part will not be subject to any major stresses then perhaps it may be worth playing with.
    Does anyone have any personal experience using sparse infill layers? Any observable difference in strength or quality?
    Posted : 23/10/2016 7:32 pm
    Mike G
    (@mike-g)
    My question is...
    Hi, Eric. Care to share your fff?
    Mike.
    Posted : 23/10/2016 10:31 pm
    joris.j
    (@joris-j)
    @Omikron : You said ' in S3D it's limited to 1.2x the layer height'. I believe this is not correct. The recommended limit is that the infill width/height should be more than 1.2. This means that for an infill layer width of 0.4 and a layer height of 0.05 you can still print 1 infill layer for every 6 perimeter layers.
    Posted : 26/10/2016 12:55 am
    Omikron
    (@omikron)
    My answer comes right from: https://www.simplify3d.com/support/faq/
    Simplify3D allows you to print a fine perimeter layer height along with a thicker infill. You'll find 'Print Sparse Infill Every __ Layer(s)' in the 'Infill' tab. Use this setting to achieve a high quality exterior while saving time printing the infill.
    The 'Sparse Infill" value you enter is related to your 'Primary Layer Height' (layer tab). The perimeter will print at your 'Primary Layer Height', and then the software will multiply the primary height by __ (the number you enter) when printing your sparse infill layers. For example, if you have a primary layer height of 0.1500 mm and set the Sparse Infill value to 2, your infill will print at 0.3000 mm (0.1500 x 2).
    For proper adhesion of layers, the software will not allow you to exceed a 1.2 ratio of width to thickness. If you exceed this ratio, Simplify3D will warn you. If you get the warning, try reducing the exterior layer height.
    Additional examples:
    0.1 mm fine exterior height - sparse infill can print every 2 or 3 layers
    0.15mm fine exterior height - sparse infill can print every 2 layers
    0.2 mm medium exterior height - sparse infill not suggested at medium or draft exterior levels
    There is a similar Sparse Infill setting under 'Support' which works in the same way to create a sparse infill in your support structures.
    Posted : 26/10/2016 2:46 am
    Ryan Neufeld
    (@ryan-neufeld)
    I think my reply was deleted, but basically S3D support told me the only way to get per material settings was to edit the xml manually.
    Posted : 26/10/2016 7:14 am
    joris.j
    (@joris-j)
    @Omikron : Just try it. With a layer height of 0.05 and a layer width of 0.4, you can have a sparse infill factor of 6 before Simplify3D complains about the width to heigth ratio of 1.2.
    Posted : 27/10/2016 1:30 am
    lus
     lus
    (@lus)
    The ratio mentioned here refers to extrusion width to exterior layer height - which makes sense, as generally maximum usable layer height is roughly 80% of nozzle width, without running into adhesion problems.
    With standard 0.4 nozzle you are good till 0.35mm, so when printing for instance at 0.05mm perimeter layer height, the multiplier could be set to '7' to print infill every 7 layers, effectively at 0.35mm.
    Posted : 30/10/2016 10:37 am
    ozyreusz
    (@ozyreusz)
    How do I generate support in S3D? When i pick the icon and generate automatic support nothing happens.
    Should I enable Generate support material in support tab of the FFF settings to be able to add support?
    Sorry I'm really new at this.
    Update
    Model was the problem. I Tried to print Zortrax superhero mask and it does not want to generate support on it
    Posted : 13/11/2016 2:58 pm
    jangrewe
    (@jangrewe)
    I just took the plunge after seeing the a YT video on the awesome support structures that S3D is able to generate (e.g. 10% for the support with a 75% layer on top), as that will allow me to save probably 50% of filament on some models with huge floating overhangs. Overall i'm very impressed by S3D, probably because so far the only slicer i've ever used (3 printers for >3 years) is CuraEngine with Octoprint 😀
    While tweaking the profile, i found a that the price/kg for PLA is set to something 200€, maybe that can be fixed in the next release 😉
    Posted : 15/11/2016 9:14 pm
    andy.b
    (@andy-b)
    You can change the price/kg for the filament you are using in the "Other" tab on your printer profile in S3D.
    Posted : 15/11/2016 10:23 pm
    StephanK
    (@stephank)
    Is anybody else seeing issue with retraction settings being too aggressive in the current version of the MK2 profile?
    I have had multiple prints (with lots of retractions) fail a couple of hours into a print because no filament is extruded anymore and i caught it printing air. If i manually push down on the filament, it starts extruding again, so its not a clog (i think) but rather (thinking again) filament being ground up and therefore getting stuck - or something entirely different going on there.
    I then went ahead and halved the retraction length to 0,4 and this time print finished fine.
    Posted : 16/11/2016 2:48 pm
    Omikron
    (@omikron)
    It could be a partial clog, meaning it gets stuck enough that it can't be pushed back down by the extruder but not so stuck that you can't manually push it forward.
    Posted : 16/11/2016 7:24 pm
    StephanK
    (@stephank)
    True enough. I guess i go back to default settings and see if it happens again after some thorough nozzle cleaning.
    Posted : 17/11/2016 5:40 am
    Page 9 / 18
