Simplify3D (S3D) settings for the Original Prusa i3 printers
Seite 18 / 18
alexander.s27
(@alexander-s27)
RE: Simplify3D print settings (August 30, 2016)
Posted by: carlos.d3
Hi guys...  I'm trying to find the latest Simplify3d profiles from alexander-s27 but I haven't been able to find them...  in the messages he states that are attached, but I cannot find any attachment or link to download from..  I really need to get help with printing with PET-G and his profile should be very useful.
Thanks!
Here is my latest S3D profile.
But be aware, I shortly thereafter switched to Slic3rPE for S3Ds remarkable Update-Pricing beaviour.
Maybe it is helpful for you, though...
Veröffentlicht : 25/04/2019 3:39 pm
alexander.s27
(@alexander-s27)
Yeah......
I neither can modify my last post nor is the uploaded file to be found anywhere....
Seems there are to be made some adjustments to that new forum....
Veröffentlicht : 25/04/2019 5:02 pm
Carlos Alberto
(@carlos-alberto)
Hi Alexander... thanks for your replies... can you please send me the files via email to "cads03" "@" "gmail.com"
Thanks!
Carlos
Veröffentlicht : 26/04/2019 1:11 pm
Irawans
(@irawans)
@alexander-s27 where is the file I could find it ?
Veröffentlicht : 28/04/2019 1:39 pm
alexander.s27
(@alexander-s27)
Posted by: Irawans
Can´t find it either.
Seems there still is alot work to be done to this new forum and its settings......
Send me your e-mail addres and you will get those files by mail.
Veröffentlicht : 29/04/2019 10:54 am
Carlos Alberto
(@carlos-alberto)
hi Alexander.. I'm still trying to figure out to to message you through this forum.. LOL... my email is "cads03" "@" "gmail.com".  Thanks for sending me the profiles this way!
Thanks!
Veröffentlicht : 29/04/2019 1:18 pm
alexander.s27
(@alexander-s27)
Thanks!
This forum really is a pain in the a.....
I already set you those files Apr. 26th to [email protected]
Veröffentlicht : 29/04/2019 4:34 pm
Carlos Alberto
(@carlos-alberto)
Got them!!  They were in the spam folder.  SORRY....
THANKS!!!
Veröffentlicht : 29/04/2019 6:09 pm
alexander.s27
(@alexander-s27)
Veröffentlicht : 29/04/2019 6:42 pm
danbst
(@danbst)
Hi alexander, sorry to be a pest but yould you please email me the fff as well please? d_baughan"@"httmail.com
Would be very much appreciated. I still struggle with custom supports in Slic3r.
Veröffentlicht : 04/05/2019 11:06 am
corey.p3
(@corey-p3)
Alexander,
Could you send me the settings as well.  coreyperez"@"hotmail.com.
Thanks in advance for your support!
Corey
Veröffentlicht : 23/05/2019 6:19 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
RE: Simplify3D (S3D) settings for the Original Prusa i3 printers
UPDATE: Official settings are out, check the first post 😉
Assembly manuals
/ Knowledge Base
Veröffentlicht : 30/05/2019 12:30 pm
Alex
 Alex
(@alex-37)
Extrusion Multiplier it's set to 0.95 instead of 1.0
Is that correct? Why is this?
Veröffentlicht : 31/05/2019 6:53 pm
Alex
 Alex
(@alex-37)
I think the profile it's not correct for ABS
Please see suggested change
Heated bed: First Layer: 100º, Rest of Layers: 110º
Best Regards,
Veröffentlicht : 03/06/2019 10:14 am
Cipis
(@cipis)
Mitglied
Yes, it is intended (0.95 for MK3 and 1.0 for MK2/2.5), to prevent overextrusion. MK2 FW is using 5% lower value for steps per mm for extruder (the same applies to MK2.5 to achieve backwards compatibility with MK2).
100C bed temperature for ABS should be fine for most of the cases, but we can change it to 110C, as you are suggesting.  Thanks.
Veröffentlicht : 10/06/2019 1:25 pm
Steve
(@steve-4)
HELP!  I am using the S3D profiles, but S3D does not want to set the temperature in the extruder.  It does set the correct temperature for the bed.  I have the temperature set correctly and the stabilize temperature check box is checked, but nothing works.
Any suggestions?
Senior Life member of IEEE.
Veröffentlicht : 29/08/2020 2:44 am
Cipis
(@cipis)
Mitglied
@stl
Just wait. Hotend temperature is set later, when the bed is ready/preheated.
Veröffentlicht : 29/08/2020 8:30 pm
Steve
(@steve-4)
Nope.  It starts printing as soon as the bed is at temperature.  The printer won't extrude because the extruder isn't heated up.  Here is the beginning gcode (I'm printing PETG):
G90
M82
M106 S128
M140 S90
M190 S90
M104 S230 T0
M109 S230 T0
M115 U3.0.7 ; use the latest firmware version
G28 W ; home all axes without mesh bed leveling
G80 ; run mesh bed leveling routine
G1 Y-3.0 F1000.0 ; prepare to prime
G92 E0 ; reset extrusion distance
G1 X60.0 E9.0 F1000.0 ; priming
G1 X100.0 E12.5 F1000.0 ; priming
; process Process1
; layer 1, Z = 0.500
T0
G92 E0.0000
G1 E-1.0000 F2400
; feature outer perimeter
; tool H0.200 W0.400
Veröffentlicht : 29/08/2020 10:10 pm
@stl
Remove T0:
M140 S90 ; set bed temp
M104 S230 ; set extruder temp
M190 S90 ; wait for bed temp
M109 S230 ; wait for extruder temp
Veröffentlicht : 30/08/2020 12:56 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
UPDATE: Link to the guide in the first post updated, also the profiles support now the Original Prusa MINI.
Diese r Beitrag wurde geändert Vor 6 years von Jakub Dolezal
Assembly manuals
/ Knowledge Base
Veröffentlicht : 03/09/2020 9:37 am
Seite 18 / 18
