Powder coated sheet for MK2S
cz7asm
(@cz7asm)
is there any way how to get powder coated sheet on MK2S? I know there's nothing official from Prusa as they stopped selling the 2.5 upgrade kit but I wonder if there's some solution that I could put directly on the smooth PEI surface. Unfortunately I missed the 2.5 upgrade and I'd like to be able to print on textured surface.
Thanks for help.
Veröffentlicht : 16/03/2021 8:57 pm
Matthew McHarg
(@matthew-mcharg)
RE: Powder coated sheet for MK2S
I bought a powder coated sheet off Amazon.  It is for the Mk 2.5/Mk3 series.  However, looking at the size, it is a couple of mm longer in 1 dimension.   I got some magnets to put on the bottom of the heat plate to hold it on.  It should come in a few days, I will try it then, and report back.
Veröffentlicht : 17/03/2021 12:33 am
Frans Krau
(@frans-krau)
I mounted magnets under the heatbed, made some sheets out of steel and used PEI from prusa and buildtalk on top of it. After that I ordered a powder coated sheet from prusa, and this works also great. The prints pop off great 🙂 No more damaged PEI sheets, mice ears, etc. I use it now for more then 2 years. Very happy with the mod 😀 😀
If you want more info, just let me know
Frans
Frans Krau
Europe, Holland, Apeldoorn
Veröffentlicht : 29/04/2021 8:50 pm
eyefly
(@eyefly)
Hi there!
The PEI-Sheet of my MK2s does not provide a good stickyness any longer sadly. Even though it still looks as new, first layers just won't stick no longer. At the moment i'm using blue tape with good results, but it's annoying to use day by day.
I'd love to use the steel spring sheet as the MK2.5+ printers are using. So the only thing that stops me from doing so are the missing magnets, that i can just add manually myself? Otherwise apart from a z-offset adjustment there is nothing else stopping me from doing so? This would be awesome.
Thanks in advance!
Veröffentlicht : 15/12/2021 11:47 am
Chicago Keri
(@chicago-keri)
Yes, you can add magnets to the original Mk42 bed and use the steel sheets.
Even though the kit is no longer available, you can also upgrade to a Mk2.5s piecemeal.   If I recall correctly, the non-printed parts you will need are:
12v Mk52 heatbed (several important differences from the 24v version for mk3)
Pinda 2 or SuperPinda
5v 40mm 3 wire hotend fan
Filament sensor and harness, The filament sensor harness is similar to Mk3, but 1 wire is in a different place at the Rambo end.
Magnet set and ball for filament sensor
Bondtech extruder gear set
2 Y-cables to adapt the 5v hotend fan and Pinda2 to the MiniRambo
Textile sleeve for extruder and nylon filament stiffener
The instructions are still available in the manuals section of Prusa's site and the printed parts are still downloadable.
And of course, after installing all of the parts, the MiniRambo must be flashed to Mk2.5s firmware
It's quite a project though!
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Veröffentlicht : 15/12/2021 6:56 pm
eyefly
(@eyefly)
Thank you so much for your reply!
I think this is a little to big of a project for me though. I really do love my MK2s still, even after so many years. I'm only doing small modifications currently, mainly to reduce the noise (upgrading to silent motor drivers and changing fans)... And I might give it a go with the magnets.
Posted by: @chicago-keri
Diese r Beitrag wurde geändert Vor 4 years von eyefly
Veröffentlicht : 15/12/2021 7:40 pm
Frans Krau
(@frans-krau)
Hi Felias,
About the stickyness of your PEI. Clean it very very good. Adjust the Z very good for the first layer. That is essential. There is enough info on this site how to do that.
About the magnets: Yes it is quit simple. Just remove the heatbed from the carrier (4 corners screws and the 2 screws of the belt). Turn over the heatbed and stick about 12 magnets (roud 12 and 5 thick). The magnets should be of very goood quality and heat resistant (100 celsius). I used heat resistant dubbel side tape. Place the mangets with the same polarity up (or down). The location of the magnets should be away from the places where the PINDA looks for its place to do the sequence for calibrating. But if your MK2 is already calibrated, you don't have te do that anymore. Remove the PEI sheet from the heatbed. You place the steelplate directly on the heatbed. Once done everything, give the printer a meshbedleveling with the steelsheet on the heatbed. The PINDA will detect the the sheet and perform the mesbed leveling. I made the steelsheets (and coverded them with the original PEI sheet from Prusa) out of a plate of steel some years ago, because it was not possible to order the Prusa sheets, due to the production problems they where facing in those days. I have now the Prusa textured sheets also in use, but only for PETG. PLA is very sensitive for wharping with these textured sheets. If you want some foto's, just let me know.
Frans, who is now printing the wordclock in Dutch 🙂
Frans Krau
Veröffentlicht : 15/12/2021 8:16 pm
eyefly
(@eyefly)
Posted by: @frans-krau
Hi Felias,
Wow, thank you so much for these detailed instructions. This is a great help!
I‘m printing 90% PLA, 5% PETG, 5% Flex. Which sheet would you think is best for me to get? From the description in the shop it seems that the satin sheet might be preferable ( https://www.prusa3d.com/product/double-sided-powder-coated-satin-spring-steel-sheet/)?
Or what are you using for PLA?
Regarding my current PEI-sheet. I think my Z-axis is well configured. Using the blue tape i‘m getting perfekt first layers and amazing prints. However i‘ll try washing with soapy water thoroughly and IPA after to see if this helps.
Veröffentlicht : 15/12/2021 10:24 pm
Frans Krau
(@frans-krau)
Hi
For PLA, I use the PEI sheet from Prusa. I just placed it on the sheet I fabricated myself 🙂
Frans
Frans Krau
Veröffentlicht : 18/03/2022 8:03 am
