PINDA probe and nozzle height issue due to bed modification
nathan.m18
(@nathan-m18)
Hello,
I have added a flexible bed to my print bed to allow me to remove the print more effectively, doing this has caused issues with the PINDA probe height. I have tried to set the probe height to suit the new bed height, but to get the nozzle high enough the probe has to be below the nozzle which is not feasible. I think I may need to adjust the Z0 height up by the thickness of the flexible bed, do you have any solutions for this?
The additional height added is 2mm.
Any help would be greatly appreciated.
Thank you,
Nathan
Respondido : 29/03/2019 12:46 pm
BillC
(@billc)
Re: PINDA probe and nozzle height issue due to bed modification
I would investigate setting z-offset in Slic3r to 2.00, and changing the start code to add a pause instruction with text "FIT PLATE NOW - press to continue" immediately after the bed levelling OR set z-offset and put M600 change filament in that position.
Bill
Tagaytay City, Philippines
Respondido : 29/03/2019 1:08 pm
