Need a new 3 Pin PINDA
Dobbalina
(@dobbalina)
- anyone know where I can get one? all the ones I have found are 4 pin.... (I am UK based)
This topic was modified 4 years temu by Dobbalina
Opublikowany : 15/12/2021 1:31 pm
RE: Need a new 3 Pin PINDA
You could try, Zaribo. Com
Opublikowany : 15/12/2021 5:03 pm
Dobbalina
(@dobbalina)
thanks for the tip but they only appear to have the 4pin connector (at a premium price I might add). I'm a bit of an electronics noob - does the 3 point connector have a special name? (ie I don't know if it is a dupont or JST connector..)
Opublikowany : 15/12/2021 5:18 pm
Chicago Keri
(@chicago-keri)
What you want is a Pinda 1.  Pinda 2 and SuperPinda have a 4-wire connector because Pinda2 used a temperature sensor.
PrintedSolid in USA still shows Pinda 1 as available.
If you had to, you could try using a SuperPinda. It has only 3 wires in the 4-pin connector, and the housing could be transferred from the old one...
The connectors are Molex, but I don't recall the type number.
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Opublikowany : 15/12/2021 7:06 pm
