Extruder cover warped
les.b4
(@les-b4)
The securing point where the fan nozel is attached to the extruder body has warped. Causing the nozel to point down. It now gets very close to the print.
Is this a common problem?
Is there a fix to stop it happening again.
If the extruder cover is replaced should the printer be fully calibrated?
Is aBS a suitable material to use for this?
I am hoping if i replace the extruder cover a complete recal is not needed as the printer is going very well.
Appreciate any comments
Thanks
Regards
Les
Publié : 22/09/2020 6:01 pm
Membre
RE: Extruder cover warped
This can happen in printing higher temperature material.  Post an image.
I printed mine with PC Blend - no more warping!
Publié : 26/09/2020 2:01 pm
jsw
 jsw
(@jsw)
My original fan shroud (ABS I assume) started to droop after a few months of heavy use, and I also reprinted it, although an 'improved' remixed one, with PC Blend.  The photo below shows both the remixed one and the original.  I printed both in PC Blend before shutting down the printer to change it.  I ended up using the newer design, as it was indeed a drop-in replacement.  It's been fine since.
Publié : 26/09/2020 3:32 pm
les.b4
(@les-b4)
@charles-h13
Thanks for replying, will post pic later
Publié : 26/09/2020 6:06 pm
les.b4
(@les-b4)
@jsw
Thanks for replying, my Fan nozell is ok but its warped on the extruder body where the fan nozell screws on.
Les
Publié : 26/09/2020 6:09 pm
Membre
@jsw
I prefer Urban Grey to show dirt better.
Publié : 26/09/2020 7:00 pm
les.b4
(@les-b4)
@charles-h13
Here is the pic.
Publié : 27/09/2020 3:01 am
Membre
That is probably from the heat.  ASA or PC Blend will prevent the warping unless you print an even hotter material.
Publié : 27/09/2020 10:23 am
les.b4
(@les-b4)
@charles-h13
Thanks,
Cant really complain, have done 40 days of printing over 3 years. very easy and quick to reprint and fit.
Although the greatest printing has been done with pla.
Publié : 27/09/2020 4:33 pm
Membre
@les-b4
It only took me a few hours with ABS temperatures to warp my first failed part.  Now, the shroud is out of, ABS, ASA, or PC Blend.
Publié : 28/09/2020 12:15 am
les.b4
(@les-b4)
@charles-h13
I made the replacement one out of ABS. I have only just started printing in ABS so probably why its just showed up.
Anyway the fix is quick so hope ABS does it.
Thanks again for your valued comments.
Publié : 28/09/2020 4:21 am
Membre
When you are ready, PC filament from 3DXMAX is great from replacement parts and it will take the heat.
Publié : 28/09/2020 12:13 pm
les.b4
(@les-b4)
@charles-h13
Thanks,
PC blend or Pure PC?. Comments please.
Publié : 28/09/2020 7:05 pm
jsw
 jsw
(@jsw)
I would use the Prusa PC Blend, as we know it to be very good.
Publié : 28/09/2020 7:09 pm
Membre
I like both filaments.  PC is tougher and I think more heat resistant but it is also more challenging to print.
Publié : 28/09/2020 7:13 pm
