Does the original MK2 have a filament runout sensor?
brian
(@brian-8)
Just like title says, does the original MK2 have a filament runout sensor and will it pause the print to reload if it detects an out-of-filament condition? Using firmware 3.2.3.
Thanks!
Respondido : 12/06/2022 11:14 pm
RE: Does the original MK2 have a filament runout sensor?
Hi Brian,
NO the Mk2 does not have a filament sensor
the updated Mk2.5 had a laser filament sensor which was problematic, and the Mk2.5S has an infrared filament sensor. unfortunately Prusa have discontinued the upgrade kit,
I believe the individual parts are still available on their website
https://www.prusa3d.com/category/mk2-5-mk2-5s/?page=3
alternatively parts are available on Ebay and Ali Express
https://www.ebay.co.uk/itm/275284595587?hash=item40183d9383:g:nKYAAOSw2ypiZCpV
https://www.ebay.co.uk/itm/304511652768?hash=item46e64f13a0:g:6qIAAOSwnFxil-Qm
https://www.ebay.co.uk/itm/293043169357?hash=item443abbe84d:g:aYwAAOSwgYlcrJJF
https://www.ebay.co.uk/itm/265582095343?hash=item3dd5ed2bef:g:sz8AAOSwV2JiKIUY
https://www.ebay.co.uk/itm/294066273790?hash=item4477b73dfe:g:PCEAAOSwVx5gT7sL
the assembly guide link is below
https://help.prusa3d.com/guide/3-upgrading-to-mk2-s-and-mk2-5s_64832#64864
Please note I believe there are custom cable adapters to convert the filament sensor and part cooling fans to work with the Mk2.5S
the Mk2.5S / Mk3S Pinda, seems a bit difficult to locate, it has 4 wires as opposed to the mk2 and Mk3S+ pinda / spinda, which have 3 wires.
the linear bearing U Bolts are available, but not essential.
Respondido : 13/06/2022 7:02 am
brian
(@brian-8)
Thank you for such a detailed reply. I appreciate it!
Respondido : 13/06/2022 6:48 pm
My Pleasure. I hope it helps.
Respondido : 13/06/2022 8:25 pm
TonyL
(@tonyl)
Just to add to this, I did the upgrade from MK2S to 2.5S using one of the "aftermarket aliexpress" kits. It went quite well, however if you go with such a kit make sure you have spare screws and nuts before you start, you can recover some from the old parts but at least in the kit I had some were missing.
Printer works as new now, at some point I’ll probably replace the "cloned ?" PINDA v2 with an original SuperPINDA. Which is why I did this upgrade in the first place, my PINDA v1 had died…
I should have bought the official upgrade package back when it was available, but eh.
Respondido : 30/06/2022 9:26 pm
