Y axis stiff/hard to push
Cody
 Cody
(@cody)
Hey everyone so this may be reaching but my y axis just seems stiff and or hard to push compared to my x axis (mk2s kit). My x axis I can push with one finger and it just glides but I've never had this with my y axis. Do you think that's normally? I have to hold the printer and pull on the y axis to get it to move. I'll attach some pictures and a short video of me pulling it. It passes the self test fine, I'm just trying to fine tune it as much as I can. Let me know if I can provide any more information.
Thanks for any help!!
[youtube] [/youtube]
Opublikowany : 08/06/2018 1:03 am
Re: Y axis stiff/hard to push
Hi Cody, your Y axis should also glide easily, could you have over tightened your bearing U bolts?
the bearings are easy to squash
Opublikowany : 08/06/2018 1:18 am
Cody
 Cody
(@cody)
Hi Joan thanks for the reply it's possible. They're so difficult to get just right. I had loosened them but then the bed was making a noise because I think they were too loose. I also think zip ties might work better.
Thanks.
Opublikowany : 08/06/2018 1:56 am
Hi Cody,
The Mk2 used Zipties
U bolts are supposed to be better...
My Mk2 MMU still has Zipties...
I have two sets of U bolts... somewhere.... when they reappear I may fit them...
Guess it's a case of what ever you feel more comfortable with
Joan
Opublikowany : 08/06/2018 1:59 am
Cody
 Cody
(@cody)
Hi Cody,
Joan
Okay well that's good to know that I can use them I may try that. That way I can't over tighten things. Thanks!
Opublikowany : 08/06/2018 2:22 am
it might be too late Cody,
if you have severely deformed the bearings, they may not recover
Opublikowany : 08/06/2018 12:46 pm
