y axis stepping/movement after pause or change filament
jaron.l
(@jaron-l)
Recently after I either pause a print or change the filament with the change filament option, after the print resumes, it starts printing a few mm "back" on the y-axis from where it should be.. Don't know what the issue is. Otherwise the printer prints immaculately.. stepping only happens when I pause or change filament.
My axes are all tight, z height is fine, although I haven't run a calibration in a while because I haven't had a need to.. Any help welcome. Thanks!
Publié : 02/06/2018 7:49 am
BillC
(@billc)
Re: y axis stepping/movement after pause or change filament
You are not pushing the bed away to better access the filament change, are you? Any movement of the bed that is not controlled by the software will throw the positioning off.
Bill
Tagaytay City, Philippines
Publié : 02/06/2018 10:17 am
