XYZ Calibration Repeatability
Hello
I recently finished my MK2S build and was very happy to see that i ran through the calibration with no problem and with perpendicular axes.
However, when i moved my printer and re ran the XYZ calibration i saw i had different skew.
I repeated the calibration and saw increasing skew.
For interests sake i tightened the bolts and re ran it again, each time with increasing skew.
I have aligned it again and the latest calibration gave me a 0.02degree skew, but i am reluctant to calibrate again in case it has changed again.
Should i not be seeing a consistent level of skew?
Why is it changing with every calibration run? DOes it really have any meaning if it can change so quickly?
Napsal : 26/12/2018 1:38 am
