XYZ calibration is successful, but getting a sensor error when trying to print v2calibration
john.p4
(@john-p4)
The selftest and XYZ calibration both run successfully (XYZ returns 'XYZ calibration ok. X/Y axes are perpendicular').
I have the top of the PINDA probe level with the cable guide, and when I run Auto Home I can fit 1 sheet of paper under the nozzle but 2 sheets is a tight fit.
Next I try to print the v2calibration using the PLA spool that came with the kit, but the print fails when it checks the 9 points and returns 'Bed leveling failed. Sensor didn’t trigger. Debris on nozzle? Waiting for reset'.
Any ideas???
Postato : 14/10/2016 8:15 pm
john.p4
(@john-p4)
Re: XYZ calibration is successful, but getting a sensor error when trying to print v2calibration
I wanted to add, I don't see any debris or filament on the nozzle.
Postato : 14/10/2016 8:20 pm
JohnOCFII
(@johnocfii)
Make sure that the bottom of the PINDA probe is approximately 0.75mm above the nozzle. If it is too high, the probe won't register. Make 1/3rd or 1/2 turns only as you get close on your adjustments.
Postato : 14/10/2016 9:43 pm
john.p4
(@john-p4)
I can definitely lower the probe a little, I'm just surprised it would pass the XYZ and then immediately afterwards fail to print with that error.
Postato : 14/10/2016 10:11 pm
ayourk
(@ayourk)
I've had this exact issue. Lowering the probe by 1 corner of the top nut fixed it.
Dimensions PNG
and an 8 inch (200mm) or greater caliper is recommended.
Postato : 15/10/2016 2:54 am
