wire disconnected during assembly
Hi, During assembly I inadvertently detached a wire
do you think it is possible to repair it or is it possible to replace only the broken piece?
Thanks for your help
Valter.
Re: wire disconnected during assembly
sorry but that connection cannot be repaired. That is the heater cartridge which happily can be replaced. Available on Prusa eshop and also from E3D. Make sure you get the right one for your printer Mk2/S uses 12V 40W, Mk3 uses 24V.
Bill
Tagaytay City, Philippines
Thanks for reply Bill
I just bought this:
HICTOP cartuccia riscaldatore 12 V 40 W 3pcs per stampante 3D Prusa i3 Mendel
I hope it's okay
bye, Valter
Personally, I would stick with original E3D parts; you know they will fit and are relatively safe to use.
Peter
