Stripped the nozzle fan connector
When I pulled the nozzle fan connection out of the board, the black wire stripped. How do I fix this? If I need to get a new connection, what type is that? Thanks in advance!
Opublikowany : 14/03/2019 8:56 pm
Re: Stripped the nozzle fan connector
If you have soldering skills and some dexterity you can extract the connector socket from the plastic and solder it back on; If not, a replacement pigtail connector could be purchased and soldered instead.
Those are commonly called "dupont connectors". Note you can get empty ones with the socket inserts but need a special crimp tool to use those, which isn't really practical unless you already have said tool.
If you don't have soldering skills, a complete replacement fan (or friend that does) is your best bet...
Opublikowany : 14/03/2019 9:19 pm
