Slic3r Prusa Edition
I downloaded a .stl file from Thingverse. I loaded it into the Slicr3 Prusa Edition included in files downloaded from Prusa website. The 3d tab as in attachment it shows properly (a hinge), and in the Preview attachment as in attachment 1 - a set of rings! It only prints a set of rings.
Posted : 30/01/2017 10:17 pm
Re: Slic3r Prusa Edition
I have seen this before while Slic3r is building the gcode. Try changing the infill percentage to force Slic3r to recreate the gcode. If the model shows up correctly, you can then change it back to what you need for the print.
Posted : 31/01/2017 8:29 pm
The model is way too small.
Posted : 31/01/2017 8:58 pm
Good catch, I didn't even notice that before. Try scaling the object uniformly 2540% as the object made have been created using the imperial system vs. metric.
Posted : 31/01/2017 9:37 pm
