Problem with LCD Display
No4
 No4
(@no4)
Hi
Since 2 weeks my LCD display looks like this.
Is it broken?
Or some software issue?
Opublikowany : 24/05/2018 10:35 pm
BillC
(@billc)
Re: Problem with LCD Display
If you are lucky its just a weak connection. Disconnect both cables at the Rambo end and replug securely, then do the same at the back of the LCD. If that does not help, then feel along each cable for evidence of a broken wire.
No luck? I would try replacement cables first and only buy a new LCD as a last resort.
Bill
Tagaytay City, Philippines
Opublikowany : 25/05/2018 2:11 am
No4
 No4
(@no4)
Hi
i have no luck, just testet the LCD from my MK3 on the Mk2 an it works fine.
How long can I guarantee the parts?
The MK2 was bought in February 2017
greets
Opublikowany : 29/05/2018 12:49 pm
Knickohr
(@knickohr)
Member Moderator
Try it, chat with PRUSA.
But anyway, such LCD controllers are really cheap to buy it at some internet stores, maybe :
https://www.ebay.de/itm/222637271152
Be carefull ! You have to rotate both ribbon connectors on one side 180° in the Rambo/Einsy or at the LCD.
Thomas
Opublikowany : 29/05/2018 1:11 pm
