Printing Issue
I was calibrating my prusa and it passed all the tests but when I started to print a rectangle as a test print. The first few layers came out great but as the print continued the print started to look rough and messed up so I stopped it. Any ideas as to why the print turned out like this and what we can do to fix it? Thanks in advance! 😀
Publié : 18/12/2018 11:02 pm
Re: Printing Issue
can you lower your live Z abit
Publié : 18/12/2018 11:25 pm
Re: Printing Issue
Check live Z and calibrate your extrusion steps. your printer could be under/over extruding. Go to matts hub.com for instructions on that. Also your temp may be too hot or not hot enough i would play with it. maybe 215C for extruder and 60C for the bed
Publié : 19/12/2018 10:58 pm
