Print issues after recalibration
My MK2 was working great until the thermistor wire got loose and blocked the Y movement. So I fixed and recalibrated but that failed initially due to an issue with the PINDA but got I readjusted it, and and recalibrated, and also did the live calibration (-.7)
Unfortunately now the prints are fine on the Y axis but are very bumpy on the X axis whereas they were smooth before (one day before- same PLA).
I was wondering if you knew why or had any calibration tips beyond the getting started videos.
X axis is very bumpy
Y is much smoother, but not as smooth as before
Thanks in advance
HELP!
Re: Print issues after recalibration
Anyone?
Not very helpful, but something else in the X-axis has come loose, moved, been damaged.
Cheers,Dave Jackson"Enthralled Nooby (not so much maybe, ~58 years old)... If 3d printers had been around 40 years ago... "
