Optimizing the Z axis setting
Rael
 Rael
(@rael)
I am a new to 3D printing just one week. However I cannot seem to get a consistent first layer. I have read the forum here and the hyper bed leveling conversation is a bit over my head. I did like the thought of printing out "test coupons" to see the difference in the Z axis offset. I have done that but I don't think that the printer is consistent in this regards. I also printed out large round shapes that came from the Castle that was loaded on the SD card that came with the printer. I have changed none of the profile settings that came with either the square calibration coupon or the Prusa Castle. Is this a case of requiring to do the hyperbed leveling or something that I am doing? Please note that I forgot to take a picture of the 0.03mm round before I took it off the bed. In all cases you can see that the print consistency goes bad as I go left and toward the front. The printer bed is level with the accuracy of 150 mm torpedo level. for all prints I have used acetone to wipe the bed before printing since I don't have access right now to 90+% alcohol. Any advise would be great. About half of the prints work the other half come loose and float around the bed.
Publié : 19/02/2019 8:18 pm
vintagepc
(@vintagepc)
Membre
Re: Optimizing the Z axis setting
Remember bed levelling is relative to the print nozzle/extruder, NOT "absolute level". Unless you made a phrasing mistake, I suspect therein lies your problem.
Bed levelling is a misnomer, it really should be called tramming.
Publié : 19/02/2019 8:21 pm
BillC
(@billc)
It will help your print surface to give better results and last much longer if you can make the effort to obtain 90% plus IPA.
vintagepc is right - the 'level' indicated by a torpedo/spirit level does not help you with setting the bed.
The hyperfine thread is still the best way to work bed level on the MK2/S but you need to find and load the hyperfine modified 3.1.0 firmware to get the 8 point adjustment in the LCD menu. With that you have the choice of the eight squares to measure thickness with a micrometer OR running the no_print_calibration g-code and using feeler gauges to measure the gap between nozzle and bed at each point.
Bill
Tagaytay City, Philippines
Publié : 20/02/2019 4:27 am
Rael
 Rael
(@rael)
Thank you both. I will do so.
Publié : 25/02/2019 7:09 pm
