New printer and first layer
phil.d2
(@phil-d2)
Hello just finished getting new printer levelbeen trying to get the first layer to stick with no joy tried everythng, havethe pinda probe down to 1mm but all i get is fillament bunching under the nozzle? on the nozle calibration i get 1 very fine line to stick but the vertical just curves and unsticks. i have used a infra red thermometer and get a few degrees off on the bed, but up to 70degrees c off on thte hot end with the fan taken off. i have adjusted the bed temp to 60degrees, tried different fillament tried the live z and got to -600 with no improvement. updated firmware.??
Opublikowany : 18/12/2016 1:29 pm
alvin.b
(@alvin-b)
Re: New printer and first layer
try to go to auto home then measure clearance of bed and nozzle with paper go to z live and adjust
Opublikowany : 26/12/2016 12:26 am
Nick
 Nick
(@nick-19)
You have made sure that the bed is properly clean after the build as their are oily parts. Try a quick clean with acetone or window cleaner if ipa doesn't do the job
Opublikowany : 26/12/2016 12:41 am
