Mesh bed levelling failed
chung yu.c
(@chung-yu-c)
Hey guys,
Need some advice and help.
Here is my issue. The mesh levelling always failed at point 3 and if it is able to clear point 3, it will fail at point 9.
The printer is printing absolutely fine printing the day before.
Of course it has failed the xyz calibration test as well and the link below is the video.
I have checked all the belt and pulleys are tight and alligned.
Thanks in advance
Napsal : 04/12/2016 3:50 am
MrMik
(@mrmik)
Re: Mesh bed levelling failed
The PINDA probe may have shifted or rattled loose.
Napsal : 04/12/2016 4:27 am
chung yu.c
(@chung-yu-c)
apparently it is secure. I will unscrew the nuts and tightened it again.
Thanks fort the suggestion and I will see whether it will solve the problem.
Napsal : 04/12/2016 4:29 am
chung yu.c
(@chung-yu-c)
I have re-secure the probe and apparently it is secure and not shaking or moving in anyway.
I tried to do a self test and more error message appear.
OMG what is happening to my machine....
Thanks in advance guys please help!
Napsal : 04/12/2016 4:50 am
MrMik
(@mrmik)
I'd open the Rambo and check if all the connectors are seated properly.
And I'd check if any cables have been damaged by rubbing against moving parts repeatedly.
Napsal : 04/12/2016 8:35 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Ensure the nozzle is clean. Lower the probe slightly. Pre-heat the bed before starting the print, with the nozzle above 10 mm height.
Peter
Napsal : 04/12/2016 9:27 am
chung yu.c
(@chung-yu-c)
Thanks Peter for the advice, I have checked the Prusa technical support and they have advised that the problem is most likely duo to the heated bed malfunctioning.
It started as a failed in mesh bed levelling.
A test on end stop value was done. A metal object was placed under the PINDA probe and the end stop value (under calibration===> shows end stops) was recorded. If the z value changes from 0 to 1 when the probe is tested at different positions on the bed, it means there is nothing wrong.
And I am waiting confirmation from Don (technical support from Prusa) to reply and send me a replacement of the mk2 heated bed.
Napsal : 07/12/2016 8:17 am
chung yu.c
(@chung-yu-c)
Re: Mesh bed levelling failed [Resolved]
Problem solved.
Prusa sent me a replacement PINDA probe and the problem was solved.
Thanks again!
https://twitter.com/godspeeeeed/status/807480586373857280
Napsal : 10/12/2016 8:24 am
