Help with odd calibration issue
TechRavingMad
(@techravingmad)
I've attached three photos of the first layer of the prusa logo. This is off of an i3 mk2 kit that I put together. Using Prusa silver PLA. All tests pass, even the XY say that they are perpendicular.
I'm having issues where the left of the bed (when facing the printer) doesn't seem to be adhering as well, but the right side seems great. This is very apparent in the corners pulling up some and when I try to print the frog the front left foot pops off before it gets attached.
If you notice in the photos, just to the left of the right white line you can see that the print changes.
Any ideas of what's causing this and what I need to do to fix it?
Publié : 11/01/2017 4:03 am
TechRavingMad
(@techravingmad)
Re: Help with odd calibration issue
A couple more pictures that hopefully show the problem better.
Publié : 11/01/2017 3:37 pm
StephanK
(@stephank)
Maybe you could try Calibration > Bed Level correction on the printer menu and raise the right side a tad.. ?
Publié : 11/01/2017 8:43 pm
