Filament stuck in PTFE inside heatsink
joshua.m17
(@joshua-m17)
Any ideas how to get this out?
This is after I unscrewed the heatsink from the extruder and it is looking back up inside it. The filament doesn’t appear to be previously melted, but I can’t get it to budge. I’ve tried pulling (yanking) at it from the bottom and ended up breaking a piece of filament off to where I can barely grab it with pliers now. I’ve also tried hammering at it from the top with one of the hex drivers and a small hammer to push it through. I also tried pulling the PTFE out from the top, but none of it will move.
Any ideas?
Thanks.
Postato : 15/07/2018 12:57 am
Rosparovac
(@rosparovac)
Re: Filament stuck in PTFE inside heatsink
MAterial? PLA can handle hairdryer, or boiling watter. For ABS, Nylon, ASA etc. Id like to use Hot air gun. If you dont have one, use oven. Just put it on baking sheet cowered wit alu foil and heat it on melting temp of inserted material. Then use pair of lineman's pliers and hold heatsink and push something 1,75mm thru ptfe. In wrost case just push new fillament.
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
Postato : 15/07/2018 2:51 am
joshua.m17
(@joshua-m17)
Thanks for the response. Good question..it’s the standard PLA 1.75mm that came with the i3 2S. I like the thought of trying the oven. I’ll give that a shot.
Postato : 15/07/2018 5:44 am
joshua.m17
(@joshua-m17)
I was able to clear it out by putting her heatsink in the oven a melting the PLA down. It took several cycles to get it all out, but it worked! I reassembled and it's printing now. Thanks for the help!
Postato : 15/07/2018 9:12 pm
coopster
(@coopster)
thanks for the tips on clearing it the jam,.... BUT my question is why does it keep happening ?... im using PLA 1.75.. on a the stock nozzle ...ive tried two different filaments and it keeps jamming in the cold end while trying to do z axis calibration...I HAVE YET TO PRINT ANYTHING. .. i I CANT EVEN GET THROUGH the calibration without it jamming! IT HAS JAMMED 4 straight times!
ive tried two different spools of PLA
ive used TWO different NEW hotend assemblies!!!!
ive replaced the PTFE Tube twice on the same assembly
ive calibrated xyz about 5 times
so ive rulled out it being a faulty hotend build.. this is my guess ,but could it be print speed vs extruder speed?
my pla when it comes out of the nozzle is very stringy and it does not stick to the bed ... it just keeps balling up by the nozzle, no matter what i do with the z height … then after about 10 minutes of trying the filament stops printing and it jams up in the coldend 5 straight times now!!!
I will post some pictures tonight of the pla and the pfte tubes that ive pulled out
Postato : 25/07/2018 5:11 pm
coopster
(@coopster)
here is some pictures
Postato : 26/07/2018 5:29 pm
coopster
(@coopster)
ok I figured it out !! thanks to someone elses problem on another post …. they mentioned how improper cooling on the hotend was causing filament problems... so it turns out the problem was the fans were switched on the motherboard 😆 🙄 😡 😳 so the nozzle fan was always on NOT the left hotend fan.... this simple mistake set me back weeks not to mention buying of parts I didn't need (I thought maybe it was a bad hotend) !! 😡 BUT this did not solve my problem with the pla not sticking to the bed...thats another story and another post
Postato : 30/07/2018 8:52 pm
Rosparovac
(@rosparovac)
Congrats
PLA dont stick too much. On new steel sheet you can always take of it with nail. If you dont like this, use a kores glue stick, which you get with you printer.
Home: MK3
Postato : 01/08/2018 10:13 pm
