Windows 11 Octoprint issues
kelsie
(@kelsie)
Octoprint worked just fine when my laptop was on W10, now that I’m on the W11 release build, it doesn’t seem to work.
I formatted the SD card for my pi and re-installed Octoprint and I still can’t get it to work.
When I do the initial ssh to connect my laptop to the pi, I just get a “connection time out” error.
Is anyone else experiencing this? How could I fix it other than going back to W10?
Postato : 19/11/2021 2:15 pm
Milos V.
(@milos-v)
RE: Windows 11 Octoprint issues
I went to W11 and have not found any issues with connection to Octoprint. At least I tried with Putty.
Try to switch off the internal firewall. I do not use it.
Postato : 19/11/2021 9:32 pm
towlerg
(@towlerg)
Suggest you raise this issue on OctoPrint forum https://community.octoprint.org/
Postato : 20/11/2021 11:50 am
kelsie
(@kelsie)
Posted by: @kelsie
I formatted the SD card for my pi and re-installed Octoprint and I still can’t get it to work cinema hd.
Solved.
Questo post è stato modificato 4 years fa 2 tempo da kelsie
Postato : 21/11/2021 3:55 pm
Zoltan
(@zoltan)
Utenti Moderator
@kelsie,
can you please share with others what was wrong to learn from you?
Postato : 21/11/2021 7:00 pm
