[Resuelto] Upgrade your Mk2.5/Mk2.5S to use the new Mk3S+ extruder
Página 2 / 2
Chicago Keri
(@chicago-keri)
Mk3S+ X carriage fits 2.5S
Posted by: @kenour
Hold up... On closer inspection the hole for the endstop-block still seems to be there on my MK3S+... It seems I just need to print another one for the MK2.5S? Am I missing something? 🤷‍♂️
Yes, the MK3S+ X carriage seems identical to the MK2.5S one, the hole exists and the end stop block fits it perfectly.
Also, the X axis motor holder / adjuster I modified fits well and the endstop switch works as expected.
I found this out today as I reprinted the X carriage, X carriage back cover and cable guide out of ASA because the PETG ones got kind of melty when my hotend heater wiring failed near the heater a couple of months ago.  It continued to work well after repairing the heater wiring but I figured it was time for inspection and maintenance as I recently ran a fairly large project.
While I had it apart, I went ahead and replaced the X axis motor and idler ends with MK3S+ ones with the idler side modified for a 5mm bore idler running on 5mm tubing and the motor end modified for an end stop switch.
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Respondido : 13/09/2021 1:31 am
Página 2 / 2
