Octopi in Pi 1B
sergio.f2
(@sergio-f2)
Octopi in Pi 1B
Hi guys
I have a Raspberry Pi 1B with Octoprint installed.
I can only connect with 11500 baud rate and I see that the prints are slower than than printing directly with the SD card, is this normal? Can be prolem of the Pi? Will I have to buy a Pi 3?
Napsal : 01/08/2018 11:02 am
BeNe
 BeNe
(@bene)
Re: Octopi in Pi 1B
The P1 B is too slow! Get yourself a Pi3 and everything will work as expected.
Napsal : 04/08/2018 9:56 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Octopi in Pi 1B
Firmware is programmed for serial operation at 115200; that's the only speed it will run at.
Peter
Napsal : 06/09/2018 5:40 pm
Baudler Art & Design
(@baudler-art-design)
Re: Octopi in Pi 1B
I just upgraded my mk2s to 2.5. My octopi can't seem to connect. I've looked under settings an don't see the RPI PORT option in the LCD. Any help extremely appreciated.
Napsal : 05/10/2018 10:41 pm
William H
(@william-h)
RE: Octopi in Pi 1B
I am running OctoPi on a 1B. Sometimes I get bad layer shift, no doubt to it not keeping up, but it works 9 out of 10 times.
Napsal : 21/10/2019 10:51 pm
William H
(@william-h)
RE: Octopi in Pi 1B
However, I just ordered a 3b to see how much better it is.
Napsal : 21/10/2019 10:59 pm
William H
(@william-h)
RE: Octopi in Pi 1B
Ok, up and running with a 3B, MUCH, MUCH, MUCH better! 😎
Napsal : 24/10/2019 3:58 am
