RE: What causes this?
Two ideas:
1) In the place where the filament on the bed shows this issue maybe the heatbed is noc clean enough?
2) Maybe a little to deep with the nozzle - I know that can be a problem on the MK2x as the heatbed has only 5 (6 - 2 screws are very close - in the same place) points where it is screwed to the y-carrier. At least on my MK2.5S the bed is not so flat - so printing big surfaces (nearly the whole bed) was allways some kind of roulette game.
Best regards, Clemens
Napsal : 31/03/2022 10:44 am
Topic starter
answered:
Thank you very much for your help. I had to print the same item again and thoroughly cleaned the surface beforehand. This time it was printed without any problem. So I assume that could have been the solution.
Napsal : 01/04/2022 3:02 pm
