MK2.5S 2nd layer thermal runaway
david.m54
(@david-m54)
HI,
Ive been printing with my prusa for 2 years now and this is the first time ive run into this problem. I recently did the 2.5 upgrade which went well and was printing fine and last week prusa sent me the 2.5s parts. Ive installed the new X carriage and extruder and the first layer print relativity well. However, as it starts the second layer, the fan kicks in on 100% and the fan appears to be cooling the hotend instead of the PLA which is causing the hot end to drop in temperature extremely quickly which leads to a thermal runaway. I have tried to roll back the firmware to both only 2.5s and to the most recent 2.5 but neither of these make any difference. So, I assume its either the fan in spinning up to fast or something else. I dont know if anyone else has experienced this.
Has anyone got any ideas as im really stuck.
Thanks in advance
David
Postato : 17/03/2019 4:11 pm
dvsing
(@dvsing)
Re: MK2.5S 2nd layer thermal runaway
I am having the same problem. Printing PLA, on the 2nd layer the part cooling fan goes to 100%, and the extruder temperature promptly drops 10-15C and is unable to sustain the target hot end temp. I noticed it because the I heard the extruder skipping steps starting on the 2nd layer. This was due to the extruder not being hot enough to melt the PLA fast enough for the printing speed being used (100mm/s Linear Advance).
I've never noticed this problem prior to upgrading from MK2.5 to MK2.5S this past weekend. I suspect this is a side-effect of the new part cooling fan shroud.
This needs to be addressed in the slicer settings (although right now there is no printer-based limits on cooling fan speed... it's all in filament setup).... and/or the part cooling shroud needs to be redesigned. I'm surprised this wasn't discovered during testing.
I can reproduce this manually with the extruder at 0.2mm Z height, hot end temp set to 215, and part cooling fan set to 255. Hot end cannot maintain 215. (Yes, I did PID calibration). If I raise the Z up to 2mm, then the hot end is able to maintain 215 (barely), and it seems to get easier the higher the Z axis is away from the print bed.
I've read others reporting the same problem in this forum. Some suggest using a silicone sock on the hot end. I don't have one of these available to test with.
I'm curious to know what Prusa's recommendation is. Has anyone contacted support about this yet?
Postato : 19/03/2019 6:56 pm
dvsing
(@dvsing)
Interesting.... in the knowledge base, under thermal runaway it says:
"Make sure the fan power settings aren't set too high in your slicer of choice. Also, check the material temperature settings. (100% fan speed is only possible with nozzle temperatures around 200°C with the V6.1 hotend.)"
If 100% fan speed is possible only with nozzle temperatures below 200C, then why does the Prusa PLA filament setting call for a 100% fan speed with a 210C temperature after the 2nd layer? This seems contradictory.
Postato : 19/03/2019 7:30 pm
Milos V.
(@milos-v)
I had this already with MK2.5, when I printed the new hotend type. It is simple cooling too much. I made two things. Replaced the heater (2.5 years old, it was already quite week not heating so fast) and bought the silicon socks. Nothing else helped, tested several custom designs from forum, but still the same.
Now ok again.
M.
Postato : 22/03/2019 4:54 pm
sopis
(@sopis)
Hi guys
I noticed the same issue and I think this is slicer related, as the slicer actually generates the gcode that would trigger the fan...
For me this however does not happen always..
I have not found any specific solution...when I see this happen I simply reduce the fan speed via print menu -> tune -> fan speed...I select random value, eg 220...this helped so far, but obviously it is not a long term solution...
However, as I stated below, this does not happen on all prints..
Postato : 12/04/2019 11:24 pm
travis_burroughs
(@travis_burroughs)
RE: MK2.5S 2nd layer thermal runaway
Hello,
Same issue here. I have 3 printers all with the mk2.5s upgrade which are all going into thermal runaway. I have reduced the the fan speed on all of them but the issue is still continuing. Any help would be greatly appreciated.
Postato : 08/02/2021 3:32 am
Jimbo70
(@jimbo70)
I had the same problem with my MK2.5s, it was very frustrating. I did the fan slow down etc. and it worked most of the time but there were still failures. Print bridging, which kicked in the high fan speed was always a problem.
May total fix was to buy a 50-watt heater cartridge for the hot end. This requires replacing the heater cartriged and rewrapping the wire bundle all the way to the computer board - about 1.5 hours of work. The fix was about 8 months ago and made my MK2.5 work like new without any adjustments to the printer setting.
I think the problem is caused by a combination of problems: old heater cartridge, and more air blowing on the hot end.
Here are some links to 50-watt cartridges. I am just giving as examples and do not necessarily recommend any certain brand. Please note that you will need to crimp on the connector for your mother board. Also, note that MK2.5 is a 12 volt system not a 24 volt system like the MK3.
Amazon.com: BCZAMD 12V 50W Upgraded Ceramic Cartridge Heater Wire 1M 3D Printer Accessories Heating Tube 620mm for Reprap Anet A8 Prusa Mendel i3 Maker Select V2 3D Printer Parts V6 Hotend J-Head Extruders 3Pcs: Industrial & Scientific
Amazon.com: WINSINN 12V 50W Heater Cartridge 620 Heating Tube HT-NTC100K Thermistor 1M for Ender 3 CR-10 Sensor Heater Block V6 J-Head Hotend Extruder 3D Printer (Pack of 5Pcs): Industrial & Scientific
Amazon.com: Geesatis 3 pcs 12V 50W 1M Ceramic Cartridge Heater 3D Printer Accessories Heating Tube for Prusa Mendel Extruder Hotend, Heating Rod 6x20mm: Industrial & Scientific
Postato : 08/02/2021 2:36 pm
