I could use some help with the Prusa Slicer
I need some help finding the correct settings in the Prusa Slicer. I've printed this box and it came 0ut nicely:
However I can't figure out to print the box inserts. When I open one of the STL files it appears to be a solid block:
and would a really long time to print. My guess is there's something in Print Settings I need to check off to get it to print just the empty shell. Any help on where to look would be very much appreciated.
RE: I could use some help with the Prusa Slicer
Flip it over. I think you will see that it is displayed with the bottom up.
Tom
Actually probably not Thomas. They are most likely designed to be printed in vase mode. Vase mode just prints a solid shape with bottom layers and a single perimeter wall. Its not supposed to be anything BUT solid, although there are some nice tricks you can do with the technique. Its a common technique for boxes and inserts.
Print Settings>Layers and Perimeters>Vertical Shells>Spiral Vase
Its also common to set your extrusion widths to be wider too, its easy to print a 0.6-0.7 thick wall from a 0.4 nozzle.  That makes the part stronger.  Does the designer not have suggested settings as part of their upload ?
Nothing in the designer notes. By fooling around with the print settings, I found that setting "Fill density" to 0 and "Horizontal shells \ Solid layers \ Top" to 0 seems to do the same thing as "Spiral Vase". I'll give it a try. Thanks.
