Extra Material on the Bottoms
I keep getting infill that renders outside of my part - or at least overlapping with the bottom walls.
The first time I saw it was when I set overlap to >25%, but this doesn't seem to be effected by that.
You can see there's material deposited that doesn't make a lot of sense.
Here's a view from the bottom:
It could be stuff that's supposed to be "inside" rendering too fat and showing on the outside, but it's hard to tell.
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Re: Extra Material on the Bottoms
It DOES scale with Bridge Flow Ratio, getting fatter when set to 2, the lines get fatter.
When I ALSO enable Detect Bridging Perimeters, the lines are hidden by the bottom lines, also rendered fat:
You can see the object in the rear has swollen bottom extrusions which better hides the swollen infill.
