Z calibration failing
marcus.m3
(@marcus-m3)
I know there are a lot of topics for this issue, but none of them helped. Here is mine:
I had a 2.5S/MMU2S up and working fine. Recognized small amount of filament dropping at the hotend after around 50 hours of printing and therefore fastened the nozzle. Then I re-calibrated the Superpinda using a ZIP as recommended. After this I wanted to calibrate Z again. This resulted in a error at Point 3. The check runs fine on point 1 and 2, at Point 3 the nozzle crashes into the bed and the display is showing "sensor not activated" (German: Sensor nicht ausgeloest).
What I did already:
- Firmware is up to date
- Superpinda re-calibrated again and again
- checked the hotend sitting in its needed place
- checked and re-fastened the screws of the bed
- cleaned and oiled the z axis
- Pinda is working (checked in Sensor Info)
It's strange that it worked without any problems before. I really only fastened the nozzle. Also point 1 and 2 are working, the at 3 it crashes the bed.
Thanks for help!!
This topic was modified 5 years temu by marcus.m3
Opublikowany : 15/03/2021 2:39 pm
