Weird behaviour following MMU removal
ian.k2
(@ian-k2)
i took off my MMU2 and have put the electronics back to scratch. Also put the standard Mk2.5 firmware back on the Prusa.
I am seeing some weird behaviour with filament loading.
Currently i have Automatic Filament loading turned off. Preheated to load PLA and then click load filament when up to temp. Filament starts to load and it asked if the colour was correct. I stated no as I wanted it to continue as the filament was not coming out. Printer moved the head to the Right Hand side of the Printer and told me to unload the filament.
Then told me the colour change was not successful !!!
It has done this 3 times tonight
Any ideas?
Napsal : 12/01/2019 9:35 pm
Re: Weird behaviour following MMU removal
Filament sensor issue, try disabling it to confirm
Joan
Napsal : 13/01/2019 12:55 am
ian.k2
(@ian-k2)
Funny you mentioned that Joan.
I have just done that as part way through another print the unit asked me to remove and then reload filament. I wondered if it was the sensor and have disabled it now.
About to try another print so will see.
Thanks for responding 🙂
Napsal : 13/01/2019 2:54 pm
