Underextrusion after Extruder upgrade
Hi!
I upgraded my MK2 Extruder to the bondtech gear version but since then i have problems with under extrusion.
Via Pronterface i tried to extrude 100mm filament but i only got 89mm. Short extrusion lenghts are very accurate but the failure increases with longer extrusion.
What am I missing? Is this a mechanical problem or did i flash the wrong firmware?
Every help is welcome I need my printer and I dont want to downgrade back to old extruder.
Thank you, CHL
Veröffentlicht : 11/11/2020 10:11 am
RE: Underextrusion after Extruder upgrade
I would check your Grub screws first.
Veröffentlicht : 24/11/2020 12:19 am
