unable to use USB
Karel
(@karel-2)
unable to use USB
I was happy user of MK2.5S until i've tried to upgrade it's firmware.
Before i was printing from SD, from PrusaSlicer (USB) or from octopi - everything was fine.
the update didn't worked, it told me right away in the begining
avrdude-slic3r -v -p atmega2560 -c wiring -P /dev/ttyACM0 -b 115200 -D -U flash:w:0:/home/charles/Downloads/prusa3d_fw_MK25S_3_9_1_3518_RAMBo13a_en-cz.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Mar 21 2020 at 18:56:46
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
Using Port : /dev/ttyACM0
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude-slic3r: ser_open(): can't open device "/dev/ttyACM0": Permission denied
avrdude-slic3r: Could not open port: /dev/ttyACM0
avrdude-slic3r done. Thank you.
but since then i'm not able to print from prusaslicer/octoprint over USB at all 🙁 not from my pc neighter raspberry is connecting 🙁   (however it's still working from SD)
in the system log i can see the printer being connected, but ...
==> /var/log/syslog <==
Sep 21 17:53:27 verdandi kernel: [  979.465023] usb 1-3: new full-speed USB device number 7 using xhci_hcd
Sep 21 17:53:27 verdandi kernel: [  979.615937] usb 1-3: New USB device found, idVendor=2c99, idProduct=0001, bcdDevice= 0.01 Sep 21 17:53:27 verdandi kernel: [  979.615944] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Sep 21 17:53:27 verdandi kernel: [  979.615948] usb 1-3: Product: Original Prusa i3 MK2 Sep 21 17:53:27 verdandi kernel: [  979.615951] usb 1-3: Manufacturer: Prusa Research (prusa3d.com) Sep 21 17:53:27 verdandi kernel: [  979.615954] usb 1-3: SerialNumber: CZPX1717X003XK18348 Sep 21 17:53:27 verdandi kernel: [  979.618015] cdc_acm 1-3:1.0: ttyACM0: USB ACM device Sep 21 17:53:27 verdandi mtp-probe: checking bus 1, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3" Sep 21 17:53:27 verdandi mtp-probe: bus: 1, device: 7 was not an MTP device Sep 21 17:53:28 verdandi mtp-probe: checking bus 1, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3" Sep 21 17:53:28 verdandi mtp-probe: bus: 1, device: 7 was not an MTP device
i've restarted both the printer and my computer, tried different usb cable but nothing helped 🙁
Postato : 21/09/2020 3:58 pm
Karel
(@karel-2)
RE: unable to use USB
in octopi terminal i found this: https://pastebin.com/9dw6GuM8 (i'm unable to paste it here due to some forum security)
i'm more and more confused, it looks as if the usb chip on the RAMBO board is broken, but then he shouldn't be able to identify himself properly - see first message in this thread
Postato : 22/09/2020 11:48 am
MediaMan3D
(@mediaman3d)
I believe I have the same issue. Same Prusa model.
avrdude-slic3r -v -p atmega2560 -c wiring -P /dev/cu.usbmodem14101 -b 115200 -D -U flash:w:0:/Users/andy/Desktop/Firmware.ino.prusa_einsy_rambo.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Jan 11 2021 at 14:04:11
Using Port : /dev/cu.usbmodem14101
avrdude-slic3r: stk500v2_recv(): timeout
avrdude-slic3r: stk500v2_getsync(): timeout communicating with programmer
avrdude-slic3r: Could not open port: /dev/cu.usbmodem14101
Same results. Were you ever able to solve the problem? If so, please share here.
Thanks.
Postato : 16/01/2021 11:33 pm
alexhill
(@alexhill)
Posted by: @mediaman3d
Thanks.
The issue has been solved after checking some tips over the Internet.
https://omegle.site/ometv
Postato : 14/04/2022 11:41 am
Clemens M.
(@clemens-m)
How are you flashing your firmware - Prusa Slicer and a USB-cable?
Could it have happened that you used the wrong version of firmware - I once had that issue, but I could reflash it. I flashed for the wrong Rambo version.
Best regards, Clemens
Postato : 14/04/2022 3:00 pm
