Selftest failing because of hotend heater/thermistor, which is working fine
qinx
 qinx
(@qinx)
Membre
I’ve had this problem before and after replacing the hotend heater and thermistor. It used to happen because of a broken thermistor, which i have replaced, but it still keeps happening. I’ve tried wiggling the cable, bending and twisting it in weird ways, resoldering the thermistor header, etc… but the problem keeps happening even though it always shows my rooms temperature: around 26°C (25.8°c). I know it’s not the hotend heater because i can feel it heat up fine. I tried factory resetting the printer but still the same issue.
If anyone has some more troubleshooting steps, maybe even a different firmware, i’ll be happy to do them.
Thanks.
PS: I tested the thermistors resistance and it’s around 100kΩs, which as i’ve researched should be 25°
Publié : 14/07/2025 7:05 pm
qinx
 qinx
(@qinx)
Membre
RE: Selftest failing because of hotend heater/thermistor, which is working fine
Update: I tried some more things and i still get the same problem, but now it fails the P.I.N.D.A calibration and i can’t load filament. It does show around the correct temperature and i also checked the set screw, which was fully in.
I would really appreciate any help
Publié : 26/07/2025 9:35 am
qinx
 qinx
(@qinx)
Membre
Another Update:
i fixed the self test error with a new thermistor and using a bypass someone found in the press support github, cant find it again sorry. Now i have to calibrate to xyz and the y/heatbed is hitting the end of the frame. i tried resetting the xyz calibration but there really isn’t any way, that i found, to  on,y calibrate the y axis or x axis.
I would reallly, REALLY appreciate any help right now
PS: Don’t know how i didn’t see this earlier but i hadn’t mentioned the model of the printer 🤦‍♂️It’s a prusa MK2.5s with the bear frame upgrade
Ce message a été modifié il y a 9 months par qinx
Publié : 01/08/2025 9:35 pm
Gt6k
 Gt6k
(@gt6k)
I have a similar issue.  I had a z axis fail during a print, it wouldn't  calibrate so went back to a full setup, failed x axis test, failed thermistor test, basically it fails every test even though I can see the respective feature is working.  I suspect that as I have done several firmware upgrades since the last full calibrate there is some incompatability that has arisen which means the calibration wizard no longer works.
Publié : 29/12/2025 10:07 am
