Remove the Firmware Warning
Screwyluie
(@screwyluie)
Does anyone know how to remove the 'this experimental firmware might destroy your pinter' warning every time the printer reboots? I use octoprint to manage the printer and it can't connect until this message is gone which means I have to be there to press the button.
make it stop. please.
Veröffentlicht : 20/03/2018 12:17 am
john.v11
(@john-v11)
Re: Remove the Firmware Warning
The safest way to go is to reflash with a supported firmware directly from Prusa. Unless you know how to compile your own firmware there is no other way to go.
Veröffentlicht : 20/03/2018 12:33 am
Screwyluie
(@screwyluie)
this is the firmware directly from prusa...
Veröffentlicht : 20/03/2018 12:34 am
digibluh
(@digibluh)
I'm starting to not like prusa for this kind of stuff. it should of been experimental when it was announced, not 6+ months later after delays and finally shipping only to say it might destroy your machine. lol.
Veröffentlicht : 20/03/2018 2:23 am
Zingabopp
(@zingabopp)
In Configuration.h:
// Firmware version
#define FW_VERSION "3.1.3-RC1"
#define FW_COMMIT_NR 276
// FW_VERSION_UNKNOWN means this is an unofficial build.
// The firmware should only be checked into github with this symbol.
#define FW_DEV_VERSION FW_VERSION_UNKNOWN
#define FW_REPOSITORY "Prusa3D/MK3"
#define FW_VERSION_FULL FW_VERSION "-" STR(FW_COMMIT_NR)
// Debug version has debugging enabled (the symbol DEBUG_BUILD is set).
// The debug build may be a bit slower than the non-debug build, therefore the debug build should
// not be shipped to a customer.
#define FW_VERSION_DEBUG 6
// This is a development build. A development build is either built from an unofficial git repository,
// or from an unofficial branch, or it does not have a label set. Only the build server should set this build type.
#define FW_VERSION_DEVEL 5
// This is an alpha release. Only the build server should set this build type.
#define FW_VERSION_ALPHA 4
// This is a beta release. Only the build server should set this build type.
#define FW_VERSION_BETA 3
// This is a release candidate build. Only the build server should set this build type.
#define FW_VERSION_RC 2
// This is a final release. Only the build server should set this build type.
#define FW_VERSION_GOLD 1
// This is an unofficial build. The firmware should only be checked into github with this symbol,
// the build server shall never produce builds with this build type.
#define FW_VERSION_UNKNOWN 0
#define FW_DEV_VERSION FW_VERSION_UNKNOWN is what you need to change, I just used FW_VERSION_GOLD
Also, you have to uncomment "//#define DEBUG_BUILD" in Configuration_prusa.h or you won't be able to print and any move commands sent over serial will put the printer in a "STOPPED" state.
Veröffentlicht : 20/03/2018 9:13 am
Screwyluie
(@screwyluie)
Thank you!
now I get to learn how to compile the firmware lol
but that's something I've been meaning to do for a while so this is good motivation.
Veröffentlicht : 20/03/2018 6:34 pm
digibluh
(@digibluh)
well the non-RC1 was released already. so you won't have to. i didn't know you were running RC.... but should of still not had that warning.
Veröffentlicht : 20/03/2018 11:15 pm
Creative Cloisters
(@creative-cloisters)
Its still the RC for Mk2.5
Veröffentlicht : 21/03/2018 3:51 pm
pcky
 pcky
(@pcky)
Perhaps Eric is talking about the release on Github: https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.1.3-MK25
Of course, it would have been nice if they did update it on the support section at the same time...
Veröffentlicht : 21/03/2018 5:48 pm
Creative Cloisters
My apologies.
I do wish they wouldn't sneak firmware out on the GitHub without updating the "user-friendly" side as well.
Its one of those little annoyances. In fact last year I didn't even know the GitHub existed.
Veröffentlicht : 21/03/2018 7:02 pm
Brian
(@brian-3)
If I download the source for final 3.1.4 here: https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.1.4
Do I have to make the modifications to #define FW_DEV_VERSION FW_VERSION_UNKNOWN and #define DEBUG_BUILD to avoid a warning message?
I am getting ready to upgrade my MK2S "Haribo" addition with the MK2.5 upgrade. I don't want to make any unnecessary firmware changes, but I also don't want to get an unnecessary warning message.
Previously I just had to change the max z from 210 to 220 and all was good.
Thanks in advance.
Veröffentlicht : 25/04/2018 4:50 am
GertL
(@gertl)
Im running the 3.14 from the webpage download.
I have no warnings.
Gert
Veröffentlicht : 25/04/2018 8:17 am
Brian
(@brian-3)
I have no warnings.
I'm not referring to the pre-compiled .hex file. I am compiling my own from the source. That is what I believe is causing the warning message.
Veröffentlicht : 25/04/2018 5:34 pm
