Rear Right Uneven bed problem
brandon.v3
(@brandon-v3)
So I just discovered that the rear right of my bed is lower then the rest. Ive done make first layer test and redid the bed. Not sure if its the carriage or the hotplate itself. If anyone else had this problem that would be great. I was wondering why my prints werent sticking on that side till I looked closely.
Thanks
Opublikowany : 31/07/2018 3:13 am
Re: Rear Right Uneven bed problem
Hi Brandon,
have you got anywhere with this?
is your main base frame twist free?
have you made sure that your Y axis smooth rods are seated properly in their cups?
have you tried bed level correction options on the LCD?
Opublikowany : 08/08/2018 1:29 am
